I searched, I promise. Electrical ? on cyclops install.
I went to Radio Shack to buy the diode needed to put my cyclops on per the write up, but they didn't have anything even close. I was directed to an electronic parts warehouse and the only diodes they had even close were 6A 400V. I am assuming these should be okay, the 400V is the load capacity it can handle, the amperage is what I need to be concerned about, right?
SeanSM - right. 6 amps is how much current you can pass thur the diode in the forward direction. 400 volts is how much voltage it will block on reverse.
