Renthal fatbar risers
I am a tool or something, I have an 2008 SM and want to raise the handlebars higher. it comes with renthal fatbars, does anyone know of a handlebar riser or new mounts that will get my bars higher? I am not interested in swapping out my triple tree btw. Thanks! :thumbsup:
Funny that you did that post, I was opening my browser to search the exact same thing on the forum and your thread is the first one on the top before I do my search :thumbsup:
ordering, thank you good sir.
You're welcome!
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
