drz-s jetting issue calif...2007
I have read just about jet post but have not seen one similar to mine.
I have a 07 drz- s converted to sm (17 wheels)ect
I do not have a Idle mixture screw on my mukuni 29fc carb (stock)
I have 3 jets
a 142.5 main
62.5 ?
22.5 pilot
It misses at idle. and a quick braap. will kill it.
It also stalls at idle sometimes. pops A lot at decell.
it is slow to take off and slow all the way up.
I have changed sprockets. 4 times now 16/40 now
and it will not go over 80 mph. level ground. 200 lb rider........
I bought it new. and it has 2000 hard miles on it now. and
it getting worse. I ride from sea level to 3500 ft regularly.
any suggestions on a first swap on the (3) jets??????
yes it does have a mixture screw.you need to remove that brass plug that is covering it.this is the same on all S/SM.
vacuum line connected to the petcock?
stock air intake hole?
yes and yes
I have 2 brass plugs
and a threadded hole that goes nowere?
the brass plug is in "stand off" on the bottom front of the carb.
do not drill the one next to the flow bowl gasket.
no problem.
I was thinking
150 main and a 25 pilot to start.
do you know the 3rd? what is the third?
I saw the link. replace the whole carb?
I will be replaceing this bike soon with a 610 or a 650
want to keep cost low. and bike stock.
coming from xr5oo and xr650r dirt and gsxr 750 track bike.
I know this bike wont last long.( the last 49 did not)
I was just looking for a jet combo to smooth it out for the next owner.
the link takes me to the airstriker jet kit with carb
JD Jetting Keihin 38mm PWK Airstriker Carburetor w/Jet Kit
List Price: $239.95
Our Price:
Ok some thing happend. now when I click on the link on my
reply I see the jet kit............. now the link works....
$72.00 thanks....
3rd clip of a aftermarket adjustable needle.
you are a perfect canidate for a JD jetting kit.
I meant what is the 3rd jet called? I have three???
