front brake
gday all tters i was out riding with my daughters bf and he a big stack and the front brake line was jammed over the front forks, like the forks had compressed and the cable fell that side. it took some getting out but now the brake is slightly sticking on... do i just undo the cable at the master cylinder.?? thanks
if the brake is dragging u may have damaged the hose, the hose could have seperated on the inside acting as a one way valve. letting the fluid past but not letting it return. check the hose
