08 YZF/WRF Radiators
No, the WR has larger radiators, though the mounts should be the same. I believe the louvers are different as well to fit their respective radiators.
You might want to double check. I think there is something else different. The only reason I say this is that if you look up fluidynes radiators 07-08 wr radiators are only the same as 06 yz radiators. The fluidynes got new part numbers for the 07 and 08 yz. I don't know if it has something do to when they tilted the yz cylinder in 07 but the wr cylinder wasn't changed.
