RM85 Tranny Oil - How much?
I just got an 03 with no manual also. And it says 550ml on the side case to. And ML is the same as CC right? And is there a check bolt anywhere just to make sure? thanks guys. I'm going to order a manual off the bay soon.
ML and CC are same. Sometimes you add less than is on the case for an oil change vs. complete overhaul. I think it says 850 on my engine but you add 750 during an oil change on my CR250.
In this case go w/ 550 if you don't have a manual. And I never use sightglass/drain port. You check oil level by changing it in a 2 stroke. Sometimes I drain into something that can hold all the oil like a Gatorade bottle to eyeball it to make sure about the correct amount comes out and to look at it closer.
my 2008 has a bolt you pull out to check the level. its on the same side as the fill plug. if you look at the case on that side you'll see a 8mm bolt on the side about 2 inches up from the bottom of the case.
