crank position
while changing valve shims the crank turned off TDC, I dont know which way it turned, so i turned it back to TDC and set valve timing, now bike wont fire, could i have turned the crank in the same direction as it fell so the spark plug is not firing on the power stroke but on the exhaust
how can i check that the TDC mark is on the power stroke
any help appreciated:worthy:
P.S i have recheck the valve clearance and it is good
