wierd shifting problem after full rebuild
im having problems shifting my bike after replacing the bottom end and replacing the bearings. the transmission look good on the bench the center fork was slightly bent had to tiny wear marks so i replaced it while it was apart. now it doesnt seem like it works right. everonce in a while the shift will not move locks up in less you push it backwards it did it 3times and i put it a way. has any one had a problem like this i think it is the shifter stop and the segment that is causing the problems with the basket of it seems like the stopper doesn't want to roll on the segment ever once in a while. if any one has a idea let me know.
