Exhaust Valve Adjustment???
ok i just cleaned my exhaust valve on my bike. 2000 rm 250 and put everything back together. now when i put the rod through the top that connects to the main valve on the left side (magneto side) the is a spring that goes on the end of that rod with a cup with a notch in it for the spring to sit in. now i put in the cup or retainer or whatever its called and gave her half a turn and screwed down the plate that holds it on. is this correct? when you move the valve rod up it pulls the valve back and im taking it the tension from the spring is supposed to bring it back down correct? seems correct. i just didnt know from before when i took it apart because the valve hardly moved. i just need to know if there is a certain spot that retainer should sit. thanks guys lemme know.
