Will you measure your axle for me?
I'm hoping a few of you have a good digital caliper and wouldn't mind measuring the diamter of your Husky 2005 or newer axle. I know they are supposed to be 25mm. i measured mine and it was 24.94 mm. Not a big deal huh? maybe, maybe not. But the spacers and wheel bearings that came with my new RAD Mfg. wheels have an inside diamter of 25.45 giving me almost .50mm of play.
Do you think this is too much? I do as evidenced by the play when I wobble the wheel side to side after it's mounted. RAD says their specs of spacers and wheel bearings have always been the same for modern Huskys and mine is the first problem they've had. So I'm hoping to compare my axle to others. Who know...maybe I got a bad axle? :headscrat
I don't have a digital caliper, but you might want to check the stock bearing # to the ones they sent you. At least that way you would know if they did send you the bearings that are susposed to fit.
