kx65 over size piston
is it true that if i put in an over sized wiseco piston like .04 for example would it fit in a stock unmodified kx65 cylender? because im looking to get the compression into the 11+ without shelling out alotta cash for the athena kit
an oversized piston is used in a larger bore cylinder, say you've had the cylinder bored a little over and replated, it's now too big for a stock piston - depending on what you've had it bored to, you will have a couple of piston sizes to accomodate the new bore size.
Use Yamabond instead of a base gasket, then get a thin head gasket from Cometic. Make sure you have enough piston to head clearance before startup.
