rear brake problem
My problem is that the rear brake works as it will stop the wheel but you can press the brake pedal all the way down after the brakes engage. I have installed brand new master cylinder and caliper. I have tried another brake line but it was used. I have bled the brake with a vacum and tried it manually. I still can press the brake pedal all the way down even though the caliper is working pressing the pads on the disk. Any suggestions?
are you talking about adjusting the brake pedal height, becauase if you go to far either way the brake pedal will not be even with the foot peg.
