KX250F engine problem
I just rebuilt my kx250f engine and when I got it all back together it would not rotatate past TDC in either direction. Before I put the head back on it was fine, It spun freely. I know the timing is right, Start from pin #1 go to pin # 28 on the timing chain and so on. Any advice would be great.
Yeah take the cam chain off make sure the cam lobes are not depressing the valves and see if you can get past tdc.
If you can then you have a timing issue
if you can't you're gonna have to tear it down again.
Since your looking at tearing down again, dont cheat and try to reuse that head gasket again. You might be able to get
by with it. I tried it and it definitely caused me problems.
g'luck
I looked at the timing again. I had the intake cam 1 tooth off. I still do not belive this is why it would not spin freely. It is fine now...👍
