chain bounce..can it be fixed??
wondering if there is a fix for my chain that bounces while riding down the road...I have an 05 s and it really annoys me....any suggestions would be great. Thanks
tighten your chain? or maybe your chain is too long try removing a few links from your chain.
Yep, it shoudnt bounce if correctly adjusted, if its hitting the SW you'll soon be in for a big bill!
Dan
Mine bounces a bit, its tight(to specs)
Doesn't hit swing arm.
Mine did that bad when I got it. Only thing that cured it was LUBE LUBE LUBE.
I think a non O-ring chain would run a little free'r.
Hard to get rid of, nature of the short stroke 4 stroke. Keep it adjusted and lubed correctly and try to forget about it.👍:worthy: vanram
I changed the upper roller from the stock plastic to a MSR and it help alot on my O7,S.
shifting to a lower gear helps
I find whin my chain starts to bounce or wip I'm in to High of gear and the motor is starting to lug
yeah, i might have to change the upper roller....I put chain wax on it all the time..still bounces
