About how much Horsepower with this Setup ???
Powroll High Compression 12:5 143cc bore kit w/ (110octane)
VM26 Carb
330X2 Cam
Titanium Valve springs
Pro-Circ T-4 exhuast
Uni Air filter lots of holes in box
vented valve cap
500ft elevation
What do you guys think this will put out in terms of horsepower to the wheel or motor. Just curious
Thanks
If Std is about 7 - 10 depending who you listen to ... I'd have thought 12 - 15
Just a guess! 👍:worthy:
Well I changed my mind on the 143 kit and I am gonna go for the big 190 kit from EO. Its only a trail bike.
The 110 race gas doesn't add a whole lot unless you can advance the timing... this set up would probably run just as well on 50/50 if not entirely on pump gas. If you could get it to 13.5:1, you could probably get 15 but realiability with an air cooled engine at that compression is questionable.
You won't regret that decision. It is an awesome conversion! :busted:👍:worthy:
