Installing new front blinkers
My bike had Acerbis plastic barkbusters with the blinkers built in but I broke one of them. Now I'm looking to install new blinkers that are mounted on the same brackets as the SM blinkers (possibly S as well). The brackets are small, black and mount to the triple clamp bolts. I would like to be able to easily remove/reinstall the blinkers for the enduros and harescrambles. Can anyone suggest a good place to purchase both the brackets and blinkers that might work well?
I doubt you'll find any aftermarket ones that can re-use the stock bracket, it's got a big weird hole right through it that only works with stock blinkers...
I'd say you have two options:
- Ask someone here for their old stock blinkers (I'll send you mine if you want to pay postage from Oz 👍 )
- Fab your own brackets and use aftermarket ones, and fab some kind of quick release to take them on and off.
Good luck.
Can someone show me a picture of the stock bracket so I can see what Rej is talking about? What other options are there?
https://thumpertalk.com/forum/garage.php?do=viewattachment&attachmentid=39053
not a stock bracket, but a simple fabbed bracket from 3/4" wide alum.stock.
i used a 10-32 bolt thru the bracket & into the blinker housing. a large flat washer inside, then a nut. needs to be installed with lense & bulb removed.
use 1/16" thick for off road, 1/8" for street.
it cuts some weight considering you ommit the stand-offs & steel brackets.
Ask a auto repair shop if you can look at their junk radiators and grab a piece of aluminum from one. I made the same brackets from a 1996 Ford Ranger Radiator. The bottom has a 2"x2' section of thin aluminum you can use
No brackets here. Shouldn't be too hard to remove them.
The whole mod took about 20 minutes.
I put mine on the front shroud also.
