noob 2003 drz 400 s full yoshi dyno jet...issues
wondering what it means when bike cuts off after riding afew minutes ,only runs on reserve? it has full tank and only 1400 miles ,should i empty tank or turn up carb screw?
if you took the tank off make sure both lines are on the petcock not just the one line. if its not that wait for other responders
like metalhead said check the vent line on the tanks petcock its the smaller hose that goes to your carb.
I thought maybe the pilot screw turned in would work ,but there doesnt seem to be one on it mukuni carb
Sure there is. It's sealed w/ a brass plug on the bottom of the carb. You have to drill out the bushing to access it. If it won't run w/ the petcock in the "ON" position, it shouldn't run w/ the petcock in the "RESERVE" position unless it's low on fuel. Try it in the "PRIME" position. If it runs here, you have a vacuum issue. There is a vacuum line that attaches to the petcock behind the fuel line, and then it attaches to the carb. on the right side:
https://thumpertalk.com/forum/showthread.php?t=307435
That line supplies vacuum to the petcock, which is vacuum operated. No vacuum, no fuel flow.
