fly wheel
hey, i have a kx 100 and im tring to get the fly wheel off and i called 2 dealers for the part and they said it would be 230$ for the fly wheel holder:banghead: is thier a way to get it off without the tool:excuseme:
all you need is 2 long bolts that fit the outside holes and a screw driver to slide between them and hold them as a wedge, the use a socket to remove the nut, you can also buy a steering wheel puller from napa use 2 long bolts and slide the ratchet extension thru the cinter bolt hole then put back on the socket to remove it, and there is about 10 other ways without a special 200 dollar tool, fyi the sterring wheel puller will also work as a case splitter and a flywheel remover, and bearing puller with just a mixture of different bolts and nuts and washers, the steering wheel puller cost 11 bucks at napa,
some grinding may be required depending on your bolt lengths.
