Ordering Parts for Motor Rebuild
Im rebuildin my motor cuz I had metal from crank in oil as well as a lose balancer shaft. Heres my list of parts im ordering. Im planning on stickin with oem honda parts unless somethings better for around the same price. What am I forgetting?
crankshaft assembly
crankshaft bearing left
crankshaft bearing right
crankshaft oil seal left
crankshaft oil seal right
middle crankcase gasket
balancer shaft
balancer bearing left
balancer bearing right
crankcase cover gasket left
crankcase cover gasket right
waterpump shaft
waterpump shaft water seal
waterpump shaft oil seal
waterpump shaft bearing
piston
piston rings
wrist pin
circlips x2
woodruff key
head gasket
cylinder gasket
cam chain
cam chain guide
cam chain internal tensioner
exhaust valve x2
intake valve x2
exhaust spring x2
intake spring x2
exhaust valve seal x2
intake valve seal x2
do i need new valve spring seats or cottors?
I will also need to get my cylinder head valve seats machined and hone out my cylinder right?
Thanks
All I know is your going to need a hell of alot of money. I did mine in March.
Why would someone yank an engine out of a new bike and sell it, is he sending the rest of the bike to Service Honda ?
He might just be parting it out.
You can buy quite a bit of that elsewhere for cheaper. Sticking with somethings OEM are good, but others why not go with an aftermarket part?
Those bearings are going to kill you if you buy them outside of a kit, Honda seems to charge double what most will for bearings.
Im planning on ordering everything from the thumpertalk oem store and the prices for most of the stuff is 40-50% cheaper than my Honda shop in town. Living in Canada most dirtbike stuff cost 30-50% more anyway. What aftermarket stuff would you use insted of stock? I was thinkin bout a 13:1 wiseco piston because its only about $30 more than stock gettin it off ebay, does anyone run one?
Any idea how much time was on the engine ? I can't imagine a true need to replace the CB shaft (bearings and seals, yes) and if the valves were fine before the teardown, I'd leave the head alone for now...Just my .02
Well I ordered the above list along with a cpl more seals for the countershaft and shifter, but I got a sweet deal on a Wiesco 13:1 piston kit so I'm goin with that. Now its just wait for the parts to arrive put it back together and get out riding. Im holdin off doin the head till winter. Im replacing the balancer shaft because the motor prob has 100ish hrs on it and I suspect it to look like the waterpump shaft with groves worn in it.
Don't forget the left side seal for the balancing shaft; it along with the right side main seal keep your tranny oil out of the engine oil....
Buy the complete engine gasket kit from TT. I did for a CR500 and it had everything.
You dont really need a new balance shaft. Just the bearings. The smart money tears it down and inspects first. The bearings in the cases may or may not need changing. Typically when you get a new crank its got the bearings and what not where you need it already.
Regarding the head: new springs, valves, and cotters.
