rear shock settings.
First, set the sag. Factory setting is a range of 3.9 to 4.1 inches (someone correct me if I'm off, please).
Then I'd set the compression and rebound clickers in the middle, and working with one setting at a time, ride and dial it in until you get a good balance.
Do the same with the front because one end affects the other.
