Back brake pads
I change mine w/o wheel removal by spreading the pads / piston apart, removing the pin holding the pads in place, and then roll the wheel backwards , the pads drop out. When you install the new ones make sure the front tabs of the pads are inserted into the slot in the caliper , then raise the back of the pads to line up the holes to insert the pin.
Do Not forget to pump the brake lever a few times before you ride , or you will have one of those warm wet feelings the first time you go for the rear brake! :)
:D AS above...no need to remove wheel or take off caliper, pull the pin, retract the piston, in with the new pads.....the only time I've removed the caliper was when I couldn't get the piston retracted :) New seals cured that!
Yep
Same for front.
BTW if you have a 98 the rear pads are a little different, held in by 2 screws but can still be changed with wheel in place.
