Not starting
I got a 98 yz125 and just replaced the top end on it. I took it up to the mountains to do some trail riding and I rode for about an hour and a half or maybe 2 hours and it will not start when i try to kick it now. It will bump start but that is it. There was no coolant in it after I was done riding and the radiator was not even hot any suggestions on what this could be?
Did you fill it back up with coolant after you replaced the top end?
that or a head gasket!
The radiator wasn't hot because there was no water in it.. how hot was the engine?
are the mountains cold? One time my bike leaked out all of its coolant (forgot to put in the drain screw back in). Then i refilled it but it had blown a head gasket so then coolant was leaking in. I noticed something was wrong so i shut the bike off. THen it would NOT kickstart, it bump started tho. I ripped off the jug and it was just filled with green goo. Unlikely that its your problem as well, but just a thought.
Yeah only run start sounds like no compression so pull the head off for a start
Or likely..
if there is coolant in the head, your spark plug should be wet or covered in green goo like mine. Either way, i agree with everyone that said rip off the jug.
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
