FCR Breathers
Hi guys,
Ive just put a new pilot jet and needle valve in my FCR carb and thought I'd take the time to re route the carb breathers to under the seat. I understand this is good idea if you ever get into deep water. As far as I can see there are two petrol overfow tubes which I assume I leave to route down by the swing arm. That leaves two on each side which seem to T off from the same place at the top of the carb. Can I simply route these upwards, I cant think of any reason why they are originally looped over the top of the carb. Or do I have to leave those loops and go around and back up?
Many thanks
Dan
Thanks William, I assume that I leave the two that come from the bottom of the tees to vent downwards as before?
Dan
