crf250r9 IMPORTANT
The crankcase bolt just behind front sprocket which holds the rocker cover drain tube bracket may not be tight from factory please check this before it falls out & catches in front sprocket...
thanks will have to let my friend know whos buying one this weekend.
Was yours loose or did someone from Honda pass this along? Good info but could be a fluke.
I work in a honda shop...3 outa 5 were loose...BUT ours are euro spec...
