Help With Math
Situation = Upcoming ride with lots of fire roads.
Problem = Stock '06 crf250x needs more room up top.
Possibility = Sprockets, 50 tooth rear and a 13 tooth front
Question = Will a stock chain fit on the a fore mentioned set up with positive results?
i had to chop 2 links when i put on my 49.
i have a 14/49 combo. see what happends with the axle blocks, maybe it'll work if you slide them all the way to the end...1 1/5 inch slack with the chain.
I need to keep up with stock 450s on this ride without burning out my motor...should that set work?
I've run a 14-48 set-up on the two track in upper Michigan and could cruise at 60 mph pretty easy and rev it out at 75 mph on a gps with my 250X.
Thanks everyone. SO I guess that means that it would work for what I need to do. Any other suggestions would be great!
:D
14/49 would work well for higher speed fire roads. Always keep the 49 on the rear, and on the front, switch back and forth between a 14(for higher speed) and 13(for stock) gear ratios. The 13/49 combo would be very close to stock. And it's easier to swap the front sprocket. Check this chart for gear ratios . If you are trying to keep up with a 450x, stock is 13/51. Not sure what the 450r has on it.
14/49 isn't that close to stock. 1 tooth front = 4 teeth rear. Stock is 14/53, which is 4 away from 14/49...so it's roughly the same as going up to a 15 on the front and leaving the rear a stock 53.
EDIT: I was apparently drunk when I wrote this. JTO's comment makes perfect sense. Please disregard.
14/53 IS stock.
14/49 IS NOT close to stock.
13/49 IS close to stock.
Running a 15 on the front(with stock rear) would also work well for higher speeds, and would be similar to the 14/49...If it will fit
Woops. I think I misread something in your post, JTO, when I wrote mine. Please disregard my comments. :worthy:
:D <-- That's me bonking me
