what is it?
whats the best shift to jump in on a kx 100?:D
im not sure what you are asking,
whats the best gear to be in to jump?
well any gear 2nd 3rd 4th 5th 6th will be a good gear to jump in depending on the jump, and you usually start doing small jumps in 2nd gear to start and work your way up till you can hit 80ft tables in 5th WOT.
overall 3rd and 4th gear are very easy to jump small doubles and such.
You choose the proper gear based on the distance of the jump, and that comes with experience. You want to be in a gear that puts you squarely in the middle of the power curve. You don,t want to be in a high gear that lugs the engine, and you don't want to be topped out in a gear either, because you need the ability to rev the bike in the air if neccessary to adjust your attitude.
