Couple questions on the 96 250 assembly
Just picked up a 95 roller with a blown motor and two 96 that run good. One 96 is a donor for the 95, when changing motors is the swingarm bolt easy to line up through the motor and frame? Do I need to use loctite on the lower motor mounts and the mount that connects the cylinder head to the frame?
These bikes are scary quick, I've always had honda's, nothing this new and big though.:D Mostly 125's and xr's.
Update, the 96 motor is in the 95. The donor frame on one of the 96 bike is in much better shape than the 95 I just put the motor in. I think I will clean it up and put the motor back into it.
