Rust on frame
there is a bit of surface rust on near the skidplate. can I use normal spraypaint? or should I use a paint that is resistant to high heat?
I used normal spray paint but it was a bit a job finding the right colour
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
