wr rad on a yz???
my buddy's fill side radiator on his 05 yz250f is smashed and looks like a gum wrapper. i have a spare radiator from my girlfriends 01 wr250f (we sold the bike a while back). will this raditor fit? i know the wr rads are larger but are the tabs the same?
thanks in advance.
jordan
It will fit and work, but some of the plastic won't line up or fit. The WR rad is 1 row of fins wider than the YZ rad, so the plastic louver that goes infront of the rad to direct air in won't work. If you get the WR louver to go with it then it will work.
The shroud should bolt on fine, but it will probably stick out farther than the other and look a little weird.
