CRF50 ignition problems
I traded my pit bike for a bone stock 07 CRF50 (time to get my daughter into riding) which supposedly had a bad CDI, I replaced the CDI and the wiring harness because it was a mess, no spark. I had a spare coil so I changed that and the spark plug, still no spark. Next I pulled the stator cover off and there it was the chain got catapulted into the ignition trigger.
Here is where my question might be stupid. Can I replace just the ignition trigger and if so where can I find one? Every where I look I find the entire ignition assembly and all I really need is the trigger. From the pictures I cannot tell if the trigger is wired into the coils and everything needs to be replaced or if it can be pulled off and replaced on its own. I don't have the correct size fly wheel puller yet to yank it and look at it.
I searched through old threads and have found problems with triggers but nothing saying how it is replaced (single piece or entire ignition plate)
Any help would be appreciated.
you can replace the whole stator plate or just the components
Best way arounf that is to search and buy a OEM Honda stator assembly someone that will sell you the Complete Honda CRf50 ignition Complete
Stator assembly: $123.89 (Stator & pick-up)
Stator plate: $28.73
Stator O-Ring: $4.43
Dont know if it will work but heres a link to a Honda OEM Parts fisch
http://webservices.motorsportdealers.com/parts/partImages/HOM/3/14GEL4/ILLUST/GELAE/1000A.Gif
website for all OEM parts:
http://www.dillon-brothers.com/pspro/Layouts/02/Skins/Centered/base/header.jpg
thanks for the info
