head's up for dual sport owners looking for a custom seat!
there's a sale at rick mayer cycle!! 'till the end of the month their dual sport saddle price is reduced by half! only 209.50$ for a custom made seat!!
thought I'd share..
I hear they are pretty good, when I bought my Corbin I was seriously considering the Mayer but they were too pricey.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
