470 loosing OIL
My 470 built by the man
seems to be needing oil after a couple rides
seems like after a 100 miles there is just a bitof oil on the dipstick
I add just a little more ,,about the length of the dipstick not alot ,just enough to reach the top line
Dont see any oil stains on the ground no visable signs of a leak,,but a riding buddy did say he smelt a bit of oil while riding
any suggestions ?
I wouldnt think so after 6000 miles
But I dont know
How could I check or test ?
But I dont know
Think you have to pull your cylinder to check this.
Should also check the valves, it can be done at the same time.
BUT IF YOUR'E SMART... Get som second opinions,as I'm no guru...:D
I have checked the valves and they were in spec
that was a couple thousand miles ago
Any other suggestions would be great
I will check for blockages in the oil return box
Most likely is the rings if there are no signs of leakage or clogged (pesky bugs!) breather. But higher than typical consumption is not a issue to immediately worry about. If you add less than a quart between 1,000 mile oil changes, then it is more of a inconvience than a pressing problem. Perhaps, in the dead of winter, a light ball honing and fresh rings may keep you out of mischief.
It is maybe an 1/2 quart every 1000 miles
WINTER ??? I think i was cold once last year
What is this ,,ball honing ,,,thing
What weight oil are you using?
What procedure are you using to check the level?
any suggestions ?
you need to call the man and tell him whats going on !!!!!!!!!!!!!!!!!!!!!!
i use up about 3 to 400ml every 1000 miles.it also depends on how you ride it.
remember to check oil while the bike is center balanced!
just saying, I thought my bike was burning oil the other day lol :D
