01 YZ 250 Shifter interchangable?
Anyone know if a same model year shifter from a 125 will fit the 250? OEM Part numbers are the same except for the first 3 digits.
How about later model YZ250's? 250f? I can only find an aftermarket shifter for the 01 from Tusk and its splines are worn out already.
Thanks :D
I run a YZ85 shifter on my YZ250 so they probably are all interchangeable.
Thats the metal one, right??? The one that wont snap like a twig when you look at it. Very smart.
I believe the people who design and build aftermarket shifters should be executed. It would be soooo nice to find one that worked.
QUOTE]
Correct again Roland, I cut it and extend it to clear the E-Line lighting coil. Steel one that is.
They are really tough.:D
