Late model CR 250 pipe difference.
I had a damn quad run into me and smash my stock pipe along with my foot. I've been looking on ebay for a used FMF or stock replacement pipe, but haven't found much. What is the difference between 02-04 and 05-07 exhausts? Is it just the flange, or more than that? They have different part numbers, so I assume they aren't interchangeable. My foot is starting to heal, so if anyone has a pipe for an 06 CR250 they want to get rid of, let me know. :D
I think is just the flange, but i might be wrong. Check the sticky at the top of the page on CR250 model changes, see if it mentions any pipe changes betweeon 04 and 05.
i have 2 stock pipes for a 05 cr 250 its the same pipe 05-07 they are listed in the classifieds here on thumpertalk. email me if intrested
I put a later model Fatty on my cr250 01 model. I just cut the flange off my old smashed pro circut pipe and cut and welded it on the fatty. I made sure the head pipe length stayed the same.
I also had to shorten my pro circuit silencer by 1.5 inches, pretty easy deal to do. Bike makes so much low mid and top now.
Also, advanced ignition timing by 2*
Bike will pull the front wheel off the ground in 4th. Kinda scary but FUN.
Motoman, what did you replace the stockers with? FMF (sst, gnarley), PC or other? What kind of gains did you get. I'm having a hard time justifying the xtra cash for a FMF gnarley, but if they really boost the bottom end then I may be able to swing it.
The gnarly is a great pipe. I have one on my cr250 and can pull the front end up when the motor is running just above idle. It makes the bike like a tractor if you have it jetted perfect and a fly wheel weight.
i had a pc platnium pipe with a pc shorty silencer, it had gobs of low to mid. got a little hairy on hard pack. when i raced on a track with hard pack i put in a 9oz flywheel wt and it just hooked up. also had a boyesen rad valve. in my opinion this combo gave the motor a great spread of power.
the cr 250 (05 in my case) worked really well in its little niche. i tried the fmf pipes and didnt care for them the seemed to rev slower. unded up with the pc products and was happy but if you wanted low end oyu had to use the platinum pie and if you wanted top get a works pipe. got tired of changing every weekend at the races and got a crf 450 again. really wish i had the cr250 still i had it set up really well and it was a great bike.:lol:
My 06' CR has a 9oz flywheel weight and Boyseen Rad valve already. I love the tight slick east coast woods and have been trying to make this thing work as good as possible. I think it has a pretty good hit in the mid so I'd like to smooth that out if at all possible.
Any one else have an opinion on FMF gnarly vs. PC platinum??
Your pipe is fine. Its custom now. Just ride it.
If you want to smooth out the power band you need a larger volume pipe, the longer the sound wave the smoother the powerband. Shorter less volume pipes make good bottom to mid but go flat on top due to the sound wave being short and quick.
Also, you have the electric power vlave, I have a friend who has been working to get the power smooth on his and still has no luck, I told him to change the carb to a keihin air striker, put a flywheel weight and see from there.
I had good luck smoothing out my 05 with a flywheel weight and keihin airstryker carb. It smoothed out even more with the JD jet kit for a YZ in the carb. The stock carb also smooths out well with a JD jet kit, but is still pretty temperamental.
Yarnall, aint no way that 300 is keeping up! So you can suck it pretty boy.
My problem is the pipe is ruined, and I need the pipe before a carb.
Damnit, there was one on ebay earlier today, but now it's gone...
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
