lowering link or not
hi guy's my bike xr650l came with the lowering link already done and the front forks are 3/4 up in the clamps.
the guy i bought it of gave me the stock link when i got it,the first year i road mostly on road but have the off road bug now:thumbsup:
sould i put the stoker back and set the front flush like the book say's?
i'm 5'10 and 165 and can't get flat footed with it now ,but if it handled better off road i think i could live with tip toeing it on road, how much would this rise the bike?
any thoughts welcome you guy's have been a great help this last year:thumbsup:
Hmmmm...sorry to see that others have not posted here. Well, let me tell you about my experience: I'm 6'2 and weigh 255. I bought my "L" from a guy who installed a lowering link and (like yours) the forks were raised in the triples accordingly. I noticed that I bottomed out the suspension a lot (especially the rear) when taking even small jumps, etc. So I found a guy here on TT who had installed a lowering link and bought his stock link. I installed it, and lowered my forks in the triples - PRESTO...no more bottoming, and it works a lot better for me.
You and I are very different size-wise, so I'm not sure that it makes sense for you to ditch the lowering link and re-adjust the front. But it definately helped in my case though. I hope this info is helpful...and I hope the bump helps you get a few more replies too! :-)
I believe the lowering link lowers an "L" appx 1 1/2" , so If removed expect it to sit an inch or so higher.
I'd just go ahead and ride it off road for awhile. Because the L is so tall and heavy most people get into trouble off road at slow speeds and trying to stop on a trail or dismount or back up. So lowering links are popular for trail riding. If you are a fast rider you will probably find it bottoms with a lowering link too much and you will want to go back to stock. Since it's easy to switch try both. Let us know what brand of lowering link you have and take some measurements of the seat height etc. Remember you have alot of adjustment at the rear shock too. Personally, I would have sold my L if I had not been able to lower it with a PD link and susp. adjustment.
thanks guy's
i went ahead and put the stock link back in and put the front forks back to stock also.
she is nose bleed high now:smirk: ,but i can still get my toe's down,and i'm pretty confortable with this bike,have 5'000+miles this year.:D
tryed it on the road and seemed much smoother,will have to get off-road tommorow.
i softend the clickers on rear shockalso how much adjustment is there?and will on lower ride higt dammpning and rebound?
could never get grease in the old link and found that the guy that did it pressed in the roller bearings to far and blocked off the grease fitting hole he also lost two rollers in one bearing ,luky for me i fond two in my junk bucket and fixed it and pressed them on the right amount and she takes grease just fine now to:banana:
also where sould the shock spring adjuster be for stock mine seem's to be near the top off adjust mybe 6 threads showing on top?
latter all
  • Similar Content
    • By XR6R Dan
      Realized this is maybe the wrong forum, please delete? Thanks.
    • By TheLastByte
      Changing out my fork oil on a new to me 650l. What's generally recommended for stock springs and valving?
    • By mrdsee
      ~177 Titanium bolts, nuts, washers etc leftover from various motorcycle projects. XR650, YZ 125, YZ250 a mix of new and used once hardware.
      Made by Mettec
      Over $2k worth of hardware
    • By Xr600guy
      So I don't seem to find my specific issue so here I am asking.
      I have a 1997 Xr600r. It was recently re-jetted and has ran really well ever since until more recently it has begun to have this issue.
      Everything works fine. Kicks right away, nice and easy. Runs great, sounds great, purs. But when I'm downshifting and slowing down to a stop, if I let my hand off the throttle that's when it just dies. I found that I can counter this by lightly holding the throttle as I down shift (so I'm revving quite a bit during downshift).  But it hadn't done this before.
      The only thing I've done that I suspect may have been an issue on my part was when I pulled out the engine to change the valve cover gasket and upon doing so perhaps when connecting the carb back to it, I may have missed something or made a crack in the boot?
      Any ideas? Thanks
    • By Kenya
      Hello all,
      There's been a lot of talk about how to register a dirt bike in states that don't allow it.
      I just moved to North Carolina and for the first time in my life might be able to afford a bike. I've been dreaming about an XR650R for a long time, but they're not cheap. Plated bikes seem to be more expensive too. So here's my question, has anyone tried to plate a dirt bike by adding all the necessary features and having it inspected as a custom bike? Anyone know of another way I can plate an xr650 in NC?
