2002 wr 250f cut miss die off idle
the bike is hard to start. it will die if you dont slowly role into the throtle. if it starts to die you have to pump the gas. the bike has 514 miles. the carb has been taken apart and cleaned. im lost this is my first four stroke.
check your valves. first indication of tight valves hard to start and will not idle unless you raise the idle up.
