Jd Kit Vs. Dynojet
HI, I rejetted my drz sm with the dynojet kit stage 3-- while I am happy with the results. I have noticed that the JD kit is highly recomended --- am I missing some hp gains by not using the JD kit ?
any thoughts would be great.
Not really, once installed and setup right, they are about the same.
The JD kit is more comprehensive, it includes the 25 pilot jet, float bowl allen bolts.
An added plus if James Dean posts here on TT and if you have problems, he is an email or phone call away. DynoJet, you speak to a script reader.
The dynojet did not have the pilot jet so i am running the stock jet, should I get the 25 will it make a difference --- small correction it;s stage 2 not 3
Yes, get the 25
You aren't loosing any power other than maybe a needle selection. I just prefer JD or factory jets over Dynojet due to their metering numbers. Dynojet = diameter of hole. JD = flow rate
Reference chart
http://www.ds650.net/mikunivsdynojet.htm
Yes, get the 25
thanks! I will get the 25:thumbsup:
