Update On Pipe Spacer
So here is just a little update.
Because of how thick it is combined with how large the OD is in relation to the thickness, it's actually kinda hard to make well!
That said, I figured out a good way to do it, and it will allow me to crank out quite a few fairly easily.
The place I am doing the machine work's owner is out of town this coming week, but by next weekend, I should be able to have them knocked out when he is back in town.
So there you go.
I may only make 3mm thickness, as it seems that's what yielded the best results after reading up on it, and it's far more practical to make.
I may squeek in a couple 1.5s, but we will see.
Anyways, expect them in about two weeks to your doors! I don't know exactly how much it will be, but Im betting around 12-15 shipped to your door AT THE MOST, I'll keep that updated, it really depends on shipping (I plan on using USPS) and any tooling I may have to purchase (not expensive for this job...no worries)
So if you want one, go ahead and say so in here, as my pm inbox will fill up too fast! When the time comes, I will get your info, and we can go from there.
Is this mod only for 250's?
I'm in!
And thank you.
aggiemoto99, I'm interested in purchasing a 3mm spacer. Thanks.
It might be tough for him to switch sizes while he is making them to the yz 250 spec. The mod would work on any bike out there. I made one years ago for a cr 85 and it worked amazingly well.
Sweet,I want one for sure.Thanks for helping every one out.
Can anyone elaborate on what the spacer accomplishes?
I made one for my 94 yz250 and couldn't tell if it made a difference.
Maybe it's because I have a gnarly FMF pipe on it, I dunno....
Put me down for one. I don't have much faith in Steahly ever coming through. Thanks :D
Put me down for 2!
Thanks aggie....I look forward to hearing when you're done making them!!
I can't wait to install it and see for myself what all the rave reviews are about.
Do the RM250s respond well to the pipe spacer as well?
Only if you mount blue plastic on them.:worthy:
I'm sure they do. You oughta get one and see. $10 or so bucks. Honestly I didn't like the changes my spacer brought. The mid range was neutered and the top end was nutz-o-matic. I'd rather have a hard mid range for off road instead. I'm keeping my spacer to mount a '02 pipe up to my scoot when my '07 pipe becomes fugly.:D
Ive seen them for sale on here, but where can I get one? I just bought a YZ and want to try this..
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
