How much is it worth?
How much would a 2005 DRZ400SM be worth?
It had 4900 miles on it in perfect condition?
Or could you direct me to a site that provides this type of info?
I just paid $3300 for a 2005 DR-Z400S with 660miles. It is in new condition.
Time of year and region and mods will determine a lot about a bike.
The west and florida has the cheapest prices because they are more common, the east coast (non-florida) seems to be the more expensive as they are more rare and the mid-west somewhere in the middle. These are just my observations. Also, this time of year is ending the riding season for a lot of bikers and so its harder to sell and prices drop.
That much mileage isn't bad for a SM model as most people buy them for daily commuting.
Is the bike bone stock? Kelly Blue Book and NADA are good guides for insurance companies and DMVs, but mods can quickly increase the value of a bike as well.
I paid $3200 for a 05 400s with 4200 miles, but it had a full yoshi rs3, brand new rear rack, included 2 brand new tires and moose hand guards.
Best of luck.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
