08 yz450f jetting help
1)2008 yz450F
2)elevation:0-3500
Temps: 70-100
Humididty:not sure, i ride cal city alot
Type of riding:Trails, c class MX, lots of hills
3)modifications (pipe,air box,motor)
Uni Air Filter
Adj Fuel Screw
Stock head pipe
FMF mid pipe and Factory 4.1 titanium
4)
Main Jet: 160
Pilot Jet: 45
Starter Jet: 72
Leak Jet: 55
Fuel screw/Setting: 1.5-2.0 turns out
Needle/Position: NFLR-3
5)
-Bike has decel pop (not a huge issue)
-The Bike has a slight hesitaion in the mid range, for example, if you use about 3/8 throttle going up a hill the bike will not want to accelerate, i have to give it more then half throttle to make accelerate up hills. Where as most bikes i have ridden will continue to accelerate.
-If i rev too quickly from no throttle to full sometimes it will die.
-If i gas it, then coast in neutral and rev the bike it will sometimes die(especially around corners) (someone told me its because i came off a 2-stroke, and i just need to get over that)
-The bike had a hesitaion up top too, i turned the needle to 1-3/4 and it completely cleaned up my top end, it rips now. however the bike is extremely hard to start.
6)The bike starts great with the choke on when cold, but once warm it can be tricky to start. the bogging conditions do not seem to be affected by temp, or altitude (i ride the high desert and Pismo Beach back to back.)
I got this suggestion from the forum
165 main
43 pilot
NFPP
50 Leak Jet
2 turns out
Do you think this will help with my jetting woes? Im starting to get really bummed out not knowing where to start.
Thanks in advance for anyones help
David
thats a good setting.
