What can I do next...(more power)
I have a 2008 crf50 with the following mods
FMF pipe
uni air filter
bbr cam
advanced timing
I would like more power, however I would like to keep the 49cc displacement.
(I want my fiddy to be a fiddy, not an 88)
I have looked through the free mods and have done pretty much everything but the head gasket mod and the choke mod. (my bike wont start without the choke)
I dont want to change the gearing. (I dont have enough torque or top speed)
Money to spent is $500 or less.
With $500 you could buy a very nice bore kit. But if you're set to stay 50cc, high compression piston, ported head, camshaft, lighten crank flywheel, titanium clutch weights, maybe a carb from a 70cc bike to go with the exhaust.
I have already put in a bbr cam (I believe white brothers actually makes it for bbr)
I really want to keep my engine size as a 49cc. I know the old saying, "there is no replacement for displacement" but I really dont want to go the route of bigbore.
when i did a search for the high compression piston, one member said that it lost power on the dyno. and a few others said it had no gains.
I will start looking for a xr/crf70 carb
has anyone tried a stroker kit for the 49cc engine?
are there any drawbacks from a lightened flywheel?
High Compression piston will raise compression and with proper tuning will definitely raise power. Powroll makes 11:1, 13:1, and 15:1 pistons for the CRF50. Stroker kit will be more displacement and will not be 49cc and you will be breaking your rule. Not to mention that a bore kit is easier and probably performs better. A stroker crank only brings you to about 60cc anyway. A lightened flywheel has no drawbacks as far as I know. If you went as far as an inner rotor you may have problems snapping cranks or exploding clutch baskets. But you will be safe with a lightened flywheel.
great info... how high of compression can I go before I have to run race gas? I would like to stick with the stuff from the pump.
11:1 would likely go fine on pump. 13:1... maybe. I wouldn't use 15:1 with pump gas though.
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: http://tboltusa.com/store/lifan-125cc-enginebrsale-price-p-1811.html ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
