06 cr 125 low end?
What can I do to get more low end out of my 125?
I've tried the 53 tooth rear sproket and that helped a little but I still want more.
thanks
thanks
What have you done so far, as in mods?
As far as mods go, I have'nt done anything. The bike is stock.
Thanks.
Thanks.
A CR125 2001-2003 silencer, Thats what we used on the dyno when we got those results(installed on 2004-2007 CR125). (This only works on the 2004-2007 CR125 Bikes/silencer.)
Take the end cap on the 2001-2003 silencer and install it on your 2004-2007 silencer.
Or have a machine shop make you a steel plug---.875" I.D. x 1.020" O.D. x .375 length, in cert the plug at the end of your 2004-2007 silencer and weld into place.
Enjoy, This one is on me. Gene
It woke up the hole power band curve----not just in one area----You will notice a difference.
On the CR125 2004-2007 they are very fat from the factory, you will need bike jetted in correctly.
