z 400 jetting help
I have an 06 suzuki z400. I ride at about 1500 feet, north carolina weather. I purchased a jd kit. I plan on just removing the snorkel cap. I have a yosh slip on. what jets would you start with? Jd instruction would lead me to think red needle 4th clip 25 pilot 155 main and two turns on fuel screw. The main jet I took out is only a 130 what do you think I should do???? Thanks for your imput.
install it exactly per the instructions.
the main jet was only 130 becuase it was jetted for the untouched air box.
