cr85 piston
Why not just pull the top end apart and measure? It doesn't take much time to do, and instead of guessing you can have piece of mind. You will need to measure both the piston and bore in order to know for sure.
when u dont have much power any more...and its hard to start sometimes
If you wait that long you're just asking for major trouble.
The stock Honda rings wear out quickly. Ours were out of spec after only 20 hours. A Wiseco top end kit will run you about $120 and includes everything you will need for a top end rebuild. Average rider will need a new top end about every 40 hours or so.
