Acribis 4gal tank
How far do you guys go before putting it on reserve? when you put it on reserve does it just let more gas into the pecock? Even when completly full do you want to have both petcocks on "on"?
"Acerbis" 4 gal tank
1) you should check the capacity of your tank. It is advertised as 4.25 gal. Mine holds about 4. Capacity may change as the tank is used.
2) I can go over 200 miles without using reserve. Depends entirely on how and where you ride.
3) The "main" tank draws from a standpipe. Reserve draws off the bottom. Just like any gas tank with reserve.
4) Both petcocks do not have to be on. I rarely turn on the right side unless I need the reserve from that side.
do you think it gets worse gas millege with both on?
I get about 160 before going to reserve, but I ride it like I stole it...:lol: the FCR and cams probably dont help but they sure make those 160 much more fun!
I do not have a petcock on the right side though, so I have to tip it over to the left if I dont go to the gas station in the first ten miles or so on reserve.
