Suzuki DRZ400sy
I have an ageing DRZ400sy year 2000, the engine is is very tired, I have been offered a crashed DRZ400e which has only 2500 miles on the clock, can I fit the 'e' engine into my 'sy' bike? I do know that I need to change the cdi unit and possibly the wiring loom, can anybody help with other mods required.
That's a good score. The E engine will drop right in and is more powerful than the S. Also, I think the 2000 S has the crappy forks and shock. Swap those also if they aren't damaged. Everything is a bolt on affair.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
