weird [wont start]
i had a floating valve on my old head and it made crazy backfire
so i took it off and replaced it with a new head new EVERYTHING even cams
its within spec
and so i put it on, new gasket, and it wont start, i put a new plug in it and i made sure the timing was right 4 times
its getting gas and has compression and it even has a brand new spark plug cap
whats the deal? :lol:
Well here is the thing, If you have GOOD compression, the RIGHT amount of fuel and spark, the bike is gonna start no matter what. So I would double check all of that, clean your carb out and make sure the jetts arent plugged, and do a compression test. It sounds to me like your either not getting fuel or your timing is off even though you said you checked it, it could be 180 degrees off.
hmmm. I agree with slampert...make sure the motor is at TDC and then check your cam timing. from the front dot on the exhaust cam to the back dot on the intake cam you should count 28 pins in the timing chain. its hard for me to explain on here lol. other than that make sure that the spark plug cap is connected properly. take the plug out and connect the spark plug cap and put the end of the spark plug on the side of the motor so it is grounded and kick the motor over with your foot without touching the motor with your hand so it wont shock you to make sure you are getting spark. again its kinda hard for me to explain without being there to show you.
How can it be 180 degrees off?
uhh yah, I dont know what the hell I was talking about, but what I was trying to say was make sure the motor is at TDC. It was a long day.
lol well it ends up the 04 head to my 05 had a VERY slight diff thread on the side allens so i just drilled em out and she went on like a glove, it didnt seal right so colant leaked into the cylinder and wet the spark =[
i took her for a spin today and i almost shit my pants, it was FAST
Good to hear!:lol:
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
