Cleaning expansion chamber
Whats the best way to clean out the inside of my FMF expansion chamber? Any suggestions or experiances are great... thanksss
I have used a braided steel wire with one end in a drill chuck. USE PROPER VENTILATION!!!
Heating the inside of the entrance of the pipe with a propane torch loosened up the main crud area well. A bristle brush knocked most of it off after the heat. Keep an eye on it so it doesn't blue to bad.
I am wanting to try capped ends and a bunch of rocks in the future.
I scraped the hard deposits, sprayed oven cleaner and let it sit for a couple of hours. Then I took a couple of handfuls of sharp edged 1/2 inch landscaping rocks from my front yard, filled the pipe about 1/4 full with water and a crap load of dishwashing soap and shook off and on for about a 1/2 hour. Turned out pretty good!
P.S. Make sure you get all the rocks out after you're done!
purple power all purpose degreaser(wally world has it) duct tape ends shut shake like a margareta rinse repeat, let soak overnight final rinse, like brandy new, change packing also, do mine once a year.
GREAT! I love the ideas guys thanks alot, Im gona try a bunch of these.
I cleaned the inside of my 1994 KDX200 pipe once. The most build-up of hard carbon was right at the entrance (cylinder to pipe connection). The oven cleaner will do well with that also. USE PROPER VENTILATION!!
Have done this many times... BBQ that bugger,really! Bury it in bricks and when they get white hot blow compressed air in it and watch the hot embers fly out.
You cant be serious.
I am waiting for the "after" pics of some shiny, $225 Pro Circuit or FMF pipe, post-BBQ. :lol:
For years, I've taken my pipes to any local engine shop or radiator shop that has a hot-tank. They usualy charge me about $20 or so to tank the pipe, and it comes out looking like a new pipe, inside and out.
thats quite a ritual, almost tribal:jawdrop:
That is really good info to hot tank the pipe. I will keep that in mind.
What exactly is a "hot tank." Do they just soak it in a tank of hot solvent?
It's a tank of hot acid.
its a tank full off hot caustic will make aluminum pistons disapear quick:eek:
What chemicals are in the hot tank??
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
