stock carb pissin gas
... it was pissing gas out of the over flow so i figured it needed a new float needle...i just rebuilt my carb and replaced the float needle and all the gaskets, still pissing and will only run with the choke on ???? wat to do???
just pulled the float apart how tight should the float be against the needle? my float seems kinda loose
make sure your float is not cracked anywhere
your float should hang loose
