KX100 won't idle...tried everything?!?
Just put a new crank, seals, bearings and top end in an older KX100 but it will not idle now. Carb is clean, power valve is clean, gas is fresh. Checked for air leaks, couldn't find any. Idle screw adjusted all the way in but the thing just dies when you let off the gas.
Any suggestions?
Any suggestions?
clogged piolt jet? float height
what altitude and jets do you have in your bike?
Check your pilot again, make sure you can see through all the holes
Reeds closing all the way? Broken tip on a reed?
My money's on a too-rich pilot jet that was being compensated for by the lean condition that the leaking crank seals were causing. Now that the crank seals no longer leak, the pilot is way too rich.
Can't argue that. :lol:
How did you test for an air leak?
i dont think hes coming back :lol:
I think my KX100 is losing it's balls (in the governor). I took it apart and the thing is stuck open. It looks like the balls were about to fall out but it didn't open quite enough to let them. I was able to get it to close on the bench but it just sticks open if I squeeze with two pairs of channel locks. Do I just press off the gear to inspect everything? The manual just says to replace damaged parts but doesnt say how to take the thing apart.?? Any help would be great! Thank you
